How do you reset ECU DTC's?
ascension_1@charter.net's avatar
dragontoy22r's avatar
dragontoy22r
I tried unplugging the ECU since removing the negative terminal hasn't worked but still no success. Anyone know how to reset the DTC on the ECU? I've made my repairs but the motor won't run right while those are keeping it in safe mode.Thanks!
skip1100's avatar
skip1100
a sure way to do it is to pull the negative side off the battery, and turn on a light to completely drain all the power thats left in the system. let it sit over night and try it in the morning.
Endless Kustoms's avatar
Endless Kustoms
yea what skyler said is right and will work and it should rest it self by moring, if not see if u have a loose cable somewhere always check for a loose cable my sdime done that after i put the batt. back on it ut jus clicked and click so i done what u said and that work fine..hoped it help u out!!!
prorida's avatar
prorida
or go to an autozone or a shmucks or crapa, and ask them to reset with a tech2. they shouldn't charge you anything. but i don't know what your ride is.
time1's avatar
time1
Take out the EFI fuse thing in the fuse block under the hood and leave it out for a minute or so.
dragontoy22r
Aight guys, I preciate the advice. I'll try them all if the drain thing doesn't work. Anyone know why disconnecting the ECU didn't work?
Thanks again!
Endless Kustoms
cause that doesnt reset anythang thats jus unhookin it thats all....
