dom vs. regular tubing
bodydropped72
im gonna be building upper and lower c-arms for a member of our club but was wondering if regular tubing would would i know dom is the way to go. but is it necessary? ill do it if it is also what wall thickness should i go with
unusualfabrication's avatar
unusualfabrication
Try this link, it refers to the topic "solid 4-link bars". Theres some good info in there.
http://www.streetsourcemag.com/forum/topic.aspx?method=reply&topic_id=96216&forum_id=93&forum_title=&M=True&S=True
BioMax's avatar
BioMax
DOM is not by any stretch necessary. It is stronger, but plain seamed tubing is stong enough.
BL
barely legal welding
heres a web site to check out if you want some more info. http://www.steeltubeinstitute.org
Richie
FreelandKustomz's avatar
FreelandKustomz
Edited: 1/17/2008 7:47:25 PM by BclassBD
Plain seemed tubing is strong enough absolutly, DOM is is great for high stress situations. here is a good example
i know this is pretty big for 4 link bars but here is a good example.
1 1/2" 250 (or 1/4" thick) round tubing is 80,000 pounds per square inch
while the same tubing in DOM is 180,000 pounds per sq inch. You really think your 4 link bars are going to see 80,000 pounds?? Or anywhere near a 1/4 of that weight. If your mounting the bags on the bars you should be using a gusset or square tubing anyways. Dom is good for high performance and high stress situations only.
bdroppeddak's avatar
bdroppeddak
those are the tensile strengh #s....
FreelandKustomz
yes it is, therefore if you have threaded bars your threads will rip out before you have an issue with your 4 link.
granth
since this thread has been answered fully, i wanted to add on about the solid link bars. actually its a question.
i have seen quite a few people lately having things laser cut from 2 inch plate, or something similar. I can get 1 inch plate, at the metal yard as scrap and wanted to know what you thought of this.
Would this be TOO heavy and mess with the way things acted, or TOO weak strength wise. Mind you its for an upper link, lowers would be 2x2 square, or laser cut 3/16 and boxed.
Would it be best to have it all laser cut and welded, or is it okay to have it 1 inch plate?
