s10 tranny problems
s10 tranny problems
slow50
my friend just bought a s10 and the dude said he put a new tranny in it and it looks clean and new or newer. but you have to force it hard to get it into gear. some times it is cool others it wont go in for shit. and everytime you put it into reverse it grinds hard or makes a loud clunk noise. he said he took it to a tranny shop and they said it was the clutch. but i dont think so cause it doesnt slip. any ideas? its a 95 manual tranny.
lx4life
IT COULD BE THE CLUTCH NOT DISINGAING ALL THE WAY. IF NOT IT COULD BE THE SINCROS, ALSO CHECK FLUID LEVEL IN IT.
jsondrops's avatar
jsondrops
and make sure it has the right fluid in it.
it takes syncromesh
MagicMikey's avatar
MagicMikey
i think those trans in the 4.3 trucks are worthless atleast the ones in the 95 models
my truck was originaly a 4.3 manual trans now its a 4.3 auto with the older noncomputerized trans. when i bought the truck used the salesman was a good guy and said if you want the truck get the waranty that covers the trans so i did and it went out, the first week but seamed good at the time. they fixed it and they spent about 2,500 on it. i drove it for a while bagged the truck and noticed then the slave cylender was on the passenger lower part of the truck. then one day is started not wanting to go in gear then it got stuck in 3rd gear. same problem as before. so i think those trans suck and i swaped mine out for the auto trans and had more ground clearance alot more.
slow50
its a 4 banger. so wrong or no fluid will cause it to not go in gear? fluid is good for the clutch master cylinder. i was also thinking its not disingaging too but can the pedal be adjusted?
Byrdman's avatar
Byrdman
if its a 4.3 engine cant u swap it out for a 350 trans auto???? if i remember correctly that is what i was told
MagicMikey's avatar
MagicMikey
yeah mine trans is the same that come with the v8s. the 4.3 is basicaly a 350 minus 2 cylenders
