elctrical problem need help asap
X
xMariox
ok heres my problem, i got a 87 b2200. and when ur use the turn siginals they work fine, but as soon as u turn the lighs on and use the turn siginals the turn lights flash dim and the tail lights will flash as well. ive checked all the bulbs and they seem to all be fine. there has been some electrical work done to it, but all wires are going in right spots. anyone have any ideas?
greenranger 23's avatar
greenranger 23
try changing the relays
So Tex Customz's avatar
So Tex Customz
grounds! check em all
midnightmike's avatar
midnightmike
mike is right^^^ check the grounds its most likely at the plug on the tail light
Twisted Galant's avatar
Twisted Galant
and again! GROUNDS. Gaurantee it!
X
xMariox
thanks guys, i ended up checking the grounds on the rear, and it ended up being the two grounds that screw to the frame, so i just cleaned em up and screwed em in a new spot and works perfect! thanks for the help.
