Air Ride Suspensions \  Bag?
Bag?
Air Ride Suspensions Q & A
views 254
replies 10
following 11
nvrloenuf   +1y
The front suspension is tight and I need to get a lot of lift.
Who makes a slim bag that gets the most lift.
Thanks..
waynehammer   +1y
slam specialties re5..
creative concepts   +1y
if you're talking about your hardbody in the picture.. you can get re7's in there with some work.. re6's fit right at home.
unusualfabrication   +1y
You can get Firestone 2600# bags in the front of a Hardbody no problem.
skip1100   +1y
I have re7s on the front of my toy. You should be able to fit re7s. and if not run re6s
AVTekk   +1y
Def do not run RE5s, they are way too small for a truck and don't get much lift. The 6s fit easily, 7s will take work but you can do it.
Tacon19s   +1y
Yeah I am in the same situation. I set up the front suspension with airlift(POS)2b6s. But I dont have enought lift to completly clear 20s...can you believe the airlift 2b6s only get a total of 6.3" of lift compared to the total of 8" of lift of a RE7? not to mention the diameters of the bags...airlifts=6.8" and Slams=7". Dude your best bet is slam specialties.
gslif   +1y
re6's upper bag plate 5.25" mold lower arm, drill hole. walla done. and dont forget to swap sides with the uppers if your planning on running anything over 20s
fatboysS1O   +1y
as everyone else said, re6s or 7s.
sledneck91604   +1y
Originally posted by gslif
mold lower arm
what do you mean by mold lower control arm?
