Wiring switches help
draggingtb@yahoo.com's avatar
draggingtb's avatar
draggingtb
So I'm gonna do my first full install soon on my friend's xA. I'm using a strut bag kit, bolt on since it's a daily, my first install and her first air ride, so i'm not worried about anything being too difficult to install. I'm good with wiring. Just a few questions. I'm sure I can figure it out when it gets here, but pointers always help. I want to use the avs brass knuckle lockout switchbox (http://www.suicidedoors.com/AVSBilletBrassKnuckle9RockerSwitch.php). This is a dumb question, but what does one wire remote dump input mean? And anyone got any general diagrams on how to properly wire a 8 valve/6 switch (front/back/individual and yes I know there will be unused switches) set up? Thanks.
unfadeble's avatar
unfadeble
you can run 12 volt positive from a alarms axillary output to allow you to dump the truck with the alarms remote
2LOW4U's avatar
2LOW4U
On the box it will tell you where to hook up each wire. I don't know the switchbox b/c I haven't used it but at the most you will run a + and - wire to each valve, or just a + and ground the valve somewhere close by.
draggingtb's avatar
draggingtb
Cool. I figured the wiring would be easy, +- for each valve, power for the box, whatnot. just wanted to check to make sure before i got into a headache of wires.
