2.3 HELP !!!
azunderground3000@yahoo.com's avatar
2.3 HELP !!!
AZ UNDERGROUND's avatar
AZ UNDERGROUND
i just aquired a 91 p/u with a 2.3 in it and its running real rough i dont want to think its major engine yet might be elec any body know any common elec issues??? please help thnx..
NR RailnPup's avatar
NR RailnPup
when mine ran rough my timing was way off
AZ UNDERGROUND
THNX i was thinkin about that myself...
eatinpavement's avatar
eatinpavement
is it all the time or just at idle? if it is just at idle, a common problem for these trucks is the intake manifold gasket. the way to check this is while its idling, spray some carburetor cleaner around where the intake manifold meets the head. if the idle picks up and smoothens out then you found your problem. the manifold gasket is sucking air and needs to be changed.
jestermetalwerx's avatar
jestermetalwerx
im sellin my 2.6 with the wiring harness for 400
