Air Ride Suspensions \  I need help someone
I need help someone
Air Ride Suspensions Q & A
views 288
replies 10
following 7
sittinonbagz   +1y
Edited: 12/13/2007 4:10:18 PM by chevylayn22s
hello i have a problem about something ok here it goes i had broke a ball joint because i had factory spindles my truck cambers in alot so i replaced the spindles with the mcgraugtys 2inch drop spindles and i thought the camber will not go away all the way but fix u know but the camber is still there i dont know why so i need help to see if i could fix the problem any suggestions would help thanks in advance
2LOW4U   +1y
Did you have an alignment shop look at it? Maybe they can adjust it more...
sittinonbagz   +1y
Edited: 12/13/2007 4:16:42 PM by chevylayn22s
naw i havent had a chance too take it so an alignment shop could fix the problem
NIGHTMARE73   +1y
IVE HEARD THAT YOU SWITCH YOUR UPPER CONTROL ARMS FROM LEFT TO RIGHT HELPS ( WHY IT WOULD I DONT KNOW !!)
sittinonbagz   +1y
i heard of that john but i really didnt think it would work
2LOW4U   +1y
Bring it to Baytown to:
Clark's Wheel & Brake Services -
2400 Market St, Baytown - (281) 422-9437
They will tell you whats up and what needs to be done. Everyone takes their bagged and lowered vehicles there b/c they know alot about them.
sittinonbagz   +1y
Edited: 12/13/2007 4:54:49 PM by chevylayn22s
u know how much they charge if thats the problem like an estimate on it i already replaced all the ball joints with moog
Master Fabber   +1y
If Im not mistaken you are always going to have some negative camber when a vehicle with unequal length control arms(shorter upper)is laidout. The only way is to go to more equal length setup. I here this handles like shit though.
NIGHTMARE73   +1y
THERES A PLACE RIGHT HERE IN HOUSTON THAT DOES ALL THE BIG WHEELS FOR US , ITS CALLED HOUSTON ALIGNMENTAND FRAME , THERE RIGHT THERE AT HILCROFT AND RICHMOND
sittinonbagz   +1y
Edited: 12/13/2007 5:21:51 PM by chevylayn22s
i hate it i cant afford to be breaking off ball joints and shit
i had talked to someone from ekstensive and they told me bout the control arms something bout angling them some shit but i dont want to talk it to ekstensive too damn high prices
