Chevy/GMC Trucks \  Truck problem
Truck problem
views 146
replies 7
following 5
CHOSN1   +1y
Not sure how to describe sound but I'm guessing it is a vacuum sound but when it rains and I start my truck it makes this sound. BUT, when I put it in drive it sounds like when you turn off a vacuum cleaner. The sound will go away and go back to normal. This only happens when it rains though.
lucky_brew   +1y
sounds like vacuum... obviously air is denser and wet when it rains so its probably making it worse during this time. do you have a check engine light or is it running bad? any idea what particualr area its coming from (ie, left side, front, etc) also, what kind of vehicle is it?
94NissanLaysDoor   +1y
i would start the truck and spray the vacuum lines with carb cleaner....when you hear the idle raise you found you issue
CHOSN1   +1y
It is my 01 GMC. This sound actually started after dragging at Battle Drag. it was raining then. When I got it back home i headed to auto zone to have em read my check engine and they couldn't get a reading. Probably due to me cutting to many wires but anyway like i said this only happens when it's been raining. Sound comes from the left side I believe. Hopefully it will rain again soon and I can look further into this
lucky_brew   +1y
you can spray it down with carb cleaner like 94nisan said... thatll work in finding it. you can also use soapy water in a spray bottle (to simulate the rain) or go to a high end parts store like carquest or napa and get a spray thats made to check that shit. a company called WYNNS also makes a produst to help find vacuum leacks and/or bad ignition parts.
lucky_brew   +1y
you still got the check engine light on???
CHOSN1   +1y
yeah, but that was on before. I just never had it checked
lucky_brew   +1y
Edited: 12/18/2007 3:55:00 PM by lucky_brew
oh... try the soapy water. just use a little at a time so you can pin-point the issue
