pinion angle
draggin04@aol.com's avatar
pinion angle
draggin04's avatar
draggin04
where should the pinion angle be set at on a 98 and up ranger
soccorjimmy's avatar
soccorjimmy
Are you referring to ride height or what? JIMMY
draggin04's avatar
draggin04
ride height or all the way down either
fkntukn1's avatar
fkntukn1
The pinion angle should be between 1 and 3 degrees pointed down. Most of us have already heard that, but the thing is that the major detail left out is that it should be 1 to 3 degrees pointed down from parallel to the transmission (or the front driveshaft on a 2 piece drive line.)
draggin04's avatar
draggin04
thanks
