Nissan Trucks \  question
question
Nissan Trucks Make Specific
views 266
replies 3
draggin04   +1y
my friends has a 2000 nissan frontier with slam bags and 18s low pros does it have to have spindles to lay out in the front, it only about a 1/4 of inch from on the ground
McClarys   +1y
get the spindles... it will help with the ball joint binding and bad cambering.. it still will camber... but not as bad...
draggin04   +1y
thanks man thats what we needed
maz duh   +1y
After you install the spindles you can put a spacer under the front bag to restore your full lifting capabilities . The 2" spindle will put you about 1 1/2 to 1 3/4 negative if its 1/4 of an inch from laying now. That would mean that the lift would be that much less. The spacer plate will fix this problem for you.
