Mini Truckin General \  blazer comes up uneven in front
views 303
replies 13
following 11
famouspimpn   +1y
hey just bought this blazer and when i hit the switch the front passgner side comes up hire then drivers side. what is it and help would be nice. it is on 1 switch for front
twistofcain   +1y
how many valves is on it
DDlowztaco   +1y
It could be many different things. If you are running the front off just one raise and one dump valve. You could check if the bags are the same height when the trucks layed out. The bag brackets could be a little uneven. Or if you have alot more air line running to one side than the other, or if there are different size fittings on each side could cause it also. If the truck has a seperate raise valve for each corner, one valve could simply be sticking when you raise it up. There could be alot of moisture in the valve and airlines.
bagged92   +1y
could be a difference in lengths of airline
disfiguredS10   +1y
Check the drivers seat and see if there's a fat guy sittin there, that's what was wrong with mine. P.S Congrats on the twins!
grillift   +1y
it could also be that one side of the vehicle is heaver than the other. this happened to mine when i was running one lift and one dump for the front.
famouspimpn   +1y
it has a valve per side and the valves are under hood in the middle. it piss me off. just want to be even.
riceeter85   +1y
do u have a sway bar? mine went up unevan before i put my sway bar in. after it was in it was fine...
kaoss   +1y
ad you a second switch so you can control both bags. I have to run about a 3-5psi difference in my bags to make it even.
famouspimpn   +1y
i hate having 2 switches
