Bass on CD but not on radio
11 following
Fazethree6661@hotmail.com's avatar
Fazethree6661's avatar
Fazethree6661
I have a cadence head unit and everything is hooked up correctly as far as I know, here is the problem that I have though. When I am playing a cd my system bumps good but when I switch over to Radio the amp is still on but no sound from the sub. I am using a 1000 watt Sony amp and a single 12 inch sony sub... I know that doesnt matter but just incase anyone wants to know.. Can anyone tell me what the problem might be?? I got the radio from a friend and he had no problems out of it.. Thanks for any help in advance...
lobdyblazr
Are the audio adjustments set different for radio mode and CD mode? just a though, but typically..you will see a lower bass response on radio.
Twisted Galant's avatar
Twisted Galant
Edited: 12/20/2007 8:58:08 PM by Twisted Galant
sure its not bass on the radio and no bass when you play the cd?
Fazethree6661
I have bass when i listen to a cd but none on the radio.. No matter how loud i have it up there is still no bass. I have tried messing with controls and no luck
Endless Kustoms's avatar
Endless Kustoms
look rest the cdplayer and it should work.....
grafix's avatar
grafix
This is gonna sound like a stupid question but ya never know .... Have you tried it on multiple radio stations or just one?
Fazethree6661
Yeah I tried mulitple stations and I thought about that same thing when i first noticed it...Im guess Im gonna pull it out again and do one last check on all the wiring and make sure its done right..
tlw32882's avatar
tlw32882
if it works when a cd is in and not the radio, it has to be something inside your stereo not any thing else
N
neurotic
its gota be a seeting on the deck. im sure is something was not hooked up right you would not have any bass at all.
IB2LOUD's avatar
IB2LOUD
some radios let you have independent controls for CD and radio, maybe the sub output is turned off on the AM/FM setting? or turned way down
if it was just your radio with bass I would say the power antenna was used for your remote, but the opposite would have to be some setting
