Ask A Pro \  Bag mount....
Bag mount....
Ask A Pro Q & A
views 246
replies 2
following 2
thacru78   +1y
Edited: 12/21/2007 11:40:20 PM by thacru78
What's up Max. Quick question. I'm having some problems with mounting my bag in the front. I'm needing close to 13 inches of lift in the front to clear the wheels. Because of this, i'm having to mount the bag close to the pivot point. Mounting it close to the pivot point is causing the bag to become off axis to a point that I don't like. I'm running Slam Re-8's and they are bending in the middle more than I want them to. My question is, do you think I can get away with mounting the bag to a pivot point. Kind of like this, but on the bottom of the bag.
The pivot would be alot shorter and maybe an inch from the bag plate. If I could get away with it, what would be best to use as a pivot point, a bushing or a heim. Thanks Max.
thacru78   +1y
Bump
BioMax   +1y
Generally speaking, a bag can be pretty "out of whack" and still be ok. The Firestone engineering manual allows as much as 45
