Mini Truckin General \  need some electrical help.
views 136
replies 3
ptman2002   +1y
i have my compressors set up on a relay and toggle switch. the switch is in between the ground wire to shut them off. when letting them run and fill the tanks, when i turn the switch off they keep running to where i have to pull the fuse. could this be a bad relay or what do you all think it could be??
disfiguredS10   +1y
sounds kinda like a stuck relay.
ShakinPlates   +1y
are you using a presure switch too?
ptman2002   +1y
Edited: 12/22/2007 1:28:52 PM by ptman2002
thanks for the help guys. found a relay in the toolbox, changed it out and it seems to be fixed. its been in there for almost 5 yrs. i guess it finally died.
