squeeking air struts
N
neonlaynkit
i recently put strut bags on my 2005 dodge neon. The ride is great and overall im pretty happy with them except for the fact that since the strut moves when you turn the car the struts squeek really bad when you turn. Is there any way to get rid of this squeek or quiet it down. Help me please!!!!!
ScrapinChevy00's avatar
ScrapinChevy00
i dont know about strut bags but i know when i have installed air cylinders in the past that the top had some urethane bushings that went in between the cylinder and the metal where the strut mounts to the car on top, so if this is some what about what you are talking about try putting some bushings or some type of rubber insulator in between it and the car, hope this helps like i said havent ever messed with strut bags before just cylinders and regular air bags.
gorillagarage's avatar
gorillagarage
which ones did you use easystreet??
LaidNeon's avatar
LaidNeon
check the upper strut mounts. the bearings might be bad
s10
last post by baha +1y
