need hlep with clearance- nissan
scottsteeb@yahoo.com's avatar
layedouton22z's avatar
layedouton22z
i just got a 1991 nissan hardbody-kingcab stock suspension 4wd and i want to lift it as cheaply as possible so i can put bigger tires under it and play. looking for any way to lift it without breaking the bank...i am sure someone has done this before...
hope pic works.
nissandoordragger's avatar
nissandoordragger
put a body lift on it it will only cost like 60 bucks or so and give you the clearance you need for bigger tires or crank the torsion bars up front and put blocks in the back or do both
gob's avatar
gob
just wondernig... how do body lifts affect the steering shaft and brake lines?
scotto79
If its the same as the pathfinder, you could just crank the front torsion bars and older F-150 front coils lift the rear a few inches. Look around on some of the 4x4 forums more.
layedouton22z
anybody know where to get the kits for them? does cranking the torsion make any real difference other than height?
nissandoordragger
Originally posted by notlowyet
If its the same as the pathfinder, you could just crank the front torsion bars and older F-150 front coils lift the rear a few inches. Look around on some of the 4x4 forums more.hardbodys dont have coils in the back they are leafs
and cranking the torsion bars will give you a stiffer bumpeir ride
layedouton22z
ok does anybody know where i can get kit for it and know someone who has offroad tires they want to get rid of. kinda open to size...not too big...let me know.
V
VtecCrx
Check craigslist for tires.
