Mazda Trucks \  front suspension??
front suspension??
Mazda Trucks Make Specific
views 403
replies 16
following 10
jealousonezenvy   +1y
i cant get my front to lay out. i got about an inch and ahlf clearance. grrrrr...I got flipped upper and lowers, no torsions, bumpstop mounts cut out. Did I forget something? anyone have pics of theres??
kaoss   +1y
what size wheel and tire? Did you trim the lower control arm were it hits the cross- member? Are your upper ball joints binding? If so, "pie" cut them. Does it layout when you take the bag out? If so, you have the bag mount to low. Hope this helps.
jealousonezenvy   +1y
no bag mounts yet...
bumlove_blue   +1y
Hey check out my post in the suspension area also search through here, cut where the lower control arm is hitting the frame
jealousonezenvy   +1y
got pics of the lower control arm cut?
bdroppeddak   +1y
just cut it where it hits the frame in the center of it.... very easy!
jealousonezenvy   +1y
so i cut it and it still sits like a inch off the ground. Nothings stopping it.??? im stumped
TwistedMinis   +1y
Are your upper balljoints binding? What size tire? Tie rods maxed out?
shorty660   +1y
i had the same prob on my 91 B2200 it was hitting the crossmember.
jealousonezenvy   +1y
im runnin 205 40x15. how can i tell if the upper ball joints binding? i haven touched the tie rod so its still set at factory
