Mazda Trucks \  91 b2200i air suspension help
Mazda Trucks Make Specific
views 165
replies 1
following 2
matrixbackman01   +1y
stock 91 b2200i 5spd std cab with A/CI ONLY WANT TO LAY FRAME as this truck will be a semi-daily driver and i already have a bd'd fullsize
wheels - 2 options here1) factory mazda's w/ 205/70/14 25.3" dia2) 18*8 5"BS +12mm offset w/ 215/45/18 25.6" dia
rear - i already have a 521 rear end that i plan to swap into this truck and if i'm not mistaken the 521 rear is about 4" narrower than the factory mazda so that takes care of clearance issues with the bedsides.
onto the front (heres where i really need some info as i'm a fullsize chevy guy) I would like to run tubular uppers and lowers, is there anybody else that makes them other than Cando?
1) can i lay frame on an almost 26" tall tire with minimal firewall/clutch/booster work?2) since my rear end is about 4" narrower than stock is there any way i can narrow the front to somewhat match?
maz duh   +1y
If you just want to lay frame with your Mazda on a 25" tire here is what you can look forward to doing...
Front: You can use stock arms up front or tubulars if you desire. The only company I'm awars of that makes a production tube arm for the Dawg is Cando. Places like Bio Kustumz or Barely Legal also make arms on a one off basis if you want a one off set. You will need a set of drop spindles for the front as well. If you stay 6 lug you are stuck with Aim spindles. If you are doing a 5 lug swap you can order arms that will accept a Toyota drop spindle from Bell Tech. You shouldn't need to move the clutch master or booster if you're looking to lay frame. You will however need to cut your fender wells and relocate a few items mounted to them for clearance. You're lucky you have a 2200i because there is very little mounted to the inner fenders. You probably won't have to tub the fire wall at all to clear and if there should be a clearance issue it will be slight.
You shouldn't need to switch out the rear end if you choose your wheel offset carefully. If you do need to make some extra room in the back a Courier rear axle is a sensible swap and is 4 inches narrower than the original rear axle.
Hopefully this helps you out a bit in your quest, hit me back if you need any more help.
