Mini Truckin General \  Valves
Valves
views 175
replies 8
following 8
drag   +1y
Ok so ive got SMC 1/2 in , when my tanks are at pressure 200psi i have one bag that is lifting on its own. ive cleaned my valves and i have no idea what is going on .
Rigo   +1y
diaphram may have a hole in it if so its got to be replaced... i've had this happen to me with 3/8's smc's before its pretty common...
snydecat   +1y
i have the same things goin on with my blitzluft blackjacks... i had one doin it and now both of the back ones are doin it.
LndRanger86   +1y
I SWITCHED MY FRONTS TO 1/2" A FEW MONTHS AGO AND ANYTHING OVER ABOUT 100lbs AND THEY LIFT UP.I JUST NEED TO UPGRADE AND DEAL WITH IT.
skip1100   +1y
buy a replacement diaphram from SD
DDlowztaco   +1y
I used to run GC valves and they were real bad about that.
TwistedPhil   +1y
We have replacement springs and diaphragms in stock- give us a call and we'll get a couple out to you!
-Phil at FBI
snydecat   +1y
thanks phil ill do that... did a little business with you guys before ill be happy to do it again.
Madness   +1y
I just used that coupon code from MT on Minitruckin.net and got the 1/2" SMC for like $38.10 or something got the stuff in two days, totally impressed, good fast service. Woot!
10% OFF OPENING SALE!!!!
Use coupon code OPENING10 to receive 10% OFF the entire website!!!
