Isuzu \  drop spindles
drop spindles
Isuzu Make Specific
views 344
replies 4
dguzzardo22   +1y
im in need if drop spindles to lay out the front on 20"s .. where can i get some?? and about how much are they? will i be able to lay it out ??
NR RailnPup   +1y
ya but you will need to notch your lower arms and pie cut your upper arms for the ball joint angle or you can flip your uppers from driver to passanger side so they r upside down thats how mine r, it works just fine
dguzzardo22   +1y
so no matter what i do im best to buy the spindles and then see where i am then cut the uppers and then lowers...
eatinpavement   +1y
if you run spindles you will need to use amigo fenders. you dont need spindles to lay on 20s
dguzzardo22   +1y
so all i have to do is notch out my lower arm and pie my uppers ???
