djm dream beams hitting oil pan! why?
teamsabotage62@yahoo.com's avatar
automatik23's avatar
automatik23
anyone got any answers or pix of your djm beams that i can see?
N
nightmare_ranger
common problem with big wheels
a9ranger
is it bagged?? i got drop beams that are'nt djm but i notched the beams and then re-enforced it, now it clears the oil pan and lays
kaptink
what size wheel do you have. or is it the crossmember?
dubDyme
that is a very common problem and unless im badly mistaking, if you have the 4 cylinder, you can get a mustang oil pan and section it enough to clear
Lexpusher96's avatar
Lexpusher96
I have Dream Beams on 2 Rangers, both lay frame on 20's and the beams don't hit the oil pan. That's funny how the same trucks can have different issues, but it happens.
automatik23
i have 20 inch wheels but even with the wheels off the truck when i jack up the suspension the passenger side beam is about 1/8" from hitting the oil pan but the truck doesn lay so i know it needs to go up more...anymore info helps
bodydropped85's avatar
bodydropped85
yota clip it. or you ahve to move the motor up. even sectioning the oilpan probably wont solve the problem. my djms busted my cast oil pan and i swapped it for a steel one and it still hit but not as bad. i have the 2.3 also.
ngacleetus's avatar
ngacleetus
Yeah, I have 4.5 traditional BD, on 18s and mine lays rocker not problemo
automatik23
yea itll lay on 18s but not 20s...ive had 17s and 18s but now i got 20s n need a lot more work lol
