Chevy/GMC Trucks \  350 into my s10
350 into my s10
views 185
replies 8
following 8
BagdMazda   +1y
Just picked up a 93 s10, looking to lay frame on 20s here pretty quickly.. while the truck is going to be off the road i thought drop a 350 in there aswell.. the truck is a 2.5 4cyl with a 5spd tranny.. question is.. will i need a diff tranny to hold up the horsepower? if so which one.. any mods im going to have to do to make the truck lay frame with a bigger motor in there? any info would be great.
Thanks
bagged&topless   +1y
i have had just about every tranny you can run with a 350 & the only one i have never had any problems with is a th350.
BagdMazda   +1y
well will this tranny bolt up to a 350? completely clueless as to what tranny is it in right know, all i no is its a 2.5l 4cyl with a 5spd manual tranny.. which could it be?
Sparkers   +1y
I have done 5 v8 conversions in s-10's, so I hope my info can help, if you are looking for a tranny to bolt up to the 350, there are a few, there is the turbo 350, turbo 400, and 700r4, (all automatic, 3 & 4 speed), to name a few, the tranny you have, the 5 speed won't bolt up, as far as I know. to lay the truck out on 20's, there are a few things you can do, you can get some iroc manifolds, but they are a little bit of a pain, what i find works best is the s-10 v8 conversion header, I like to us headman, just personal preferance. and for the a-arms not to hit the header when layed out, you might wanna look into Air Ride Tech. Upper arms, or Suicide Doors, they miss the header completly. there are a lot of web sites to help you though. Good luck.
brknnkz   +1y
im puttin in a 400 sbc into my s10...wanting a 6 speed manual tranny but having a bitch of a time finding one. any suggestions? sorry to jack the thread btw
bdroppeddak   +1y
Edited: 1/14/2008 5:27:02 AM by bdroppeddak
t 5-6 is your only option for a 6 speed manual... not hard to find at all, richmond sells one through all the performance dealers....
the 2.5 l trans will not bolt up to a 350... cheapest trans you can get for it would be the th350... but you have alot of options, th350, th400, powerglide, 700r4, 200r4, 4l60e, 4l80e, nv3500, nv4500, the tremec 5 speed and 6 speeds, muncie 4 speeds, lots and lots of trannys!!!
idrgbdy   +1y
what about my 4.3L in my '96 sonoma? will that tranny/rearend work with the 350 i just picked up? everone i talked to says it will work. but i'm wondering if i should just swap in one of the tranny's described above.
menace   +1y
yeah on the 4.3L it has the 700r4 transmission it will bolt right up, as for the rearend it depends how much power you plan on running...
mmrcustoms   +1y
brnkknz--- get a t56 out of a LT1 camaro, that is the only 6speed that will fit a non-LS1 motor. i am going to use the same tranny with a 383ci and s10 V8 swap headers
