Seth Twisted minis Question for you......
adgate2@hotmail.com's avatar
Adgate2's avatar
Adgate2
so since your the MMFIC on toytoa's, got a question for you,
On my yota I raised the lower crossmember up 1 inch witch brought up the lower arms up 1 inch, how would you go about correcting the sterring??
what I did is replaced the ball joint with a hime and fliped it over to the bottom side of the spindle.
Is that right?
the reason Im asking is the sterring still does some crazy shit when I cycle the front all the way up, to all the way down.
also the front gets about 12/13 inches of lift....witch might even be the problem....
anyways what do you think????
thanks
Steve Severed Ties cen cal
1lowfatkid's avatar
1lowfatkid
ok.. i guess i'll ask the stupid question? what is MMFIC? its gotta be something "in charge"
Adgate2's avatar
Adgate2
MAIN MOTHER FUCKER IN CHARGE YOU KNOW THIS.............
layingnutz
I WAS GONNA SAY MASTER MOTHERFU**ER IN CHARGE
Adgate2's avatar
Adgate2
doesnt seth live in SSM, can some one knock on a fourm and wake him up??
1lowfatkid's avatar
1lowfatkid
LOL oh thats going in my sig right now
TwistedMinis's avatar
TwistedMinis
I was going to ask,w hat is MMIFC? Lol. Its been answered. It takes time to answer though Steve, and try to find the diagram I wanted.
Anyways, without looking at it I can tell you a few things. 12-13 inches of travel is a lot, but you should be able to control the amount of toe in and out within that range. My truck does 11" and I have about 2.5 degrees of toe in laid out, and about 2 degrees toe out all the way up. I still have my alignment sheet somewhere too if you needs specs from it.
But, the issues that you are having are related to the alignment of the 6 pivot points on your front suspension. Max has a good diagram showing this, but I can't find it right now. So I made one in paint.
Basically all of the pivots on the spindle should be in a straight line, and same with the pivots on the frame. Also, the distance between the lower balljoint and the tie rode (or heim), should be the same distance as between the LCA bushing and the pivot on the steering. This is the first thing I would check. That heim may need to be spaced down, or the spacers you have now may need to be shaved down some to make it correct. That will probably be the fastest fix for this.
Your other option, would be to move the steering box and idler arm up the same amount the LCA pivot has been moved up. Either one will work just as well.
Adgate2's avatar
Adgate2
Thanks seth, Ill see if I can shave the mis alignment spacer on the hiem down, Ill see if that helps my prob......
Steve
