Ask A Pro \  toyota / wilwood brake kit
Ask A Pro Q & A
views 430
replies 8
following 6
mikedee   +1y
max, i am installing the kit for a customer, i believe it was bought from bio.its a 89/94 toyota. my problem is spacing between the calipers and mounting bracket, supplied with the kit. if im doing something wrong i dont know what it is. you can see i made spacers for the passenger side to center the caliper to the rotor. the driver side was completely different. the thickness was about half on the driver side. look at the pics and tell me what you think. i appreciate any help. thanks
mikedee   +1y
bump
BioMax   +1y
It sound strange that the spacers would be different from side to side. What you have looks to be fine, as long as the caliper is somewhat centered on the rotor it should work well. The 4 piston calipers are pretty forgiving.
e10pvmt   +1y
max, do you still sell this kit or just the bracket.....there is a DIY kit for 4wd calipers but i am wanting wilwood all the way around...shit if i can get the bracket off of you, just lemme know what rotors and rotor hats i need as well as model # on calipers...lemme know
stromad   +1y
http://www.phattys.ca/ might be able too hook you up with what your looking for!!
e10pvmt   +1y
ya but i aint lookin to spend a grand...i love that kit though
BioMax   +1y
I'm sure that Tony would sell you just the brackets and give you his part numbers. His stuff is nearly identical to mine. His is just machined.
Give him a try, tell him I told you to ask him first. If he still won't help then we can talk.
TOYBOY89   +1y
Almost the same as my front brakes, bracket is almost the same, except I didnt use spacers, and my rotor is a toyota supra rotor instead of wilwood. Check out my profile. I have extra brackets too and can make more.
BioMax   +1y
There ya go.
