Chevy/GMC Trucks \  95 and up dash
95 and up dash
views 128
replies 3
Dustins10   +1y
i have a 94 1500 and i wanted to know how hard it is to put the 95 and up dash in thanks
simple-pleasurez   +1y
i was curious how hard it would be to do the same. except in a 91 since there are no options for custom gauges for a 91
prorida   +1y
i would imagine mounting would not be a prob, since it's the same cab, so the mounting points are the same. you would have to get matching door panels, i bought the window regulaters with the door panels for the mounting points. my only question would be on the cluster, not sure if you could just re-pin the harness, i'm sure you could re-pin your climate controls.
Then you would have to get all heater vent tubes, so i think if you were getting the dash from a junk yard. take everything you can.
ixenn   +1y
Changing the dash defiantly does NOT change your wiring harness lol you won't be able to use different gauges. The newer gauges are alot different.
