cando arms with bigger then a 19....
E
F
FBCsmiley
does anybody have 19s or bigger layed out on a tacoma using cando arms. jus wondering wat kinda spacer u used and if anybody has any pics? thanx
simple-pleasurez's avatar
simple-pleasurez
call steve at cando. he will help you with anything. dude loves to talk. call to ask about his cando arms and get a lesson on how to properly mow your grass. but he is cool as shit.
simple-pleasurez
correction. learn how to run bigger than 19's and how to properly cut your lawn.
Tacon19s's avatar
Tacon19s
Edited: 1/23/2008 11:30:47 AM by Tacon19s
lol, yeah steve is cool. I setup my taco to run 20s with just cando uppers and flipped lower balljoints and it layed out fine, but had terrible toe issues. I was told by flipping the ball joints it increased the bumpsteer. so I put everything back in its stock location and then of course had the problem of it not laying out.I was gonna also use a spindle spacer but wanted them to be fully welded to the spindle, and since I cant TIG at all and I will be driving the truck daily I sold the uppers and I just went ahead and bought biocustomz spindles. they really are worth the money man. It can be done with a spacer and cando upper arms I believe with a little more work. The best setup I have seen is PDOGs taco. looks like maybe an 1.5" spacer....good luck.
slammedxonair's avatar
slammedxonair
right off steves site..........
OK so here's the deal with the taco a-arms and laying 20's......, you have to put some spacers between the lower balljoint/tie-rod end bracket (it's one piece) the rack is pivoted to it's limit up to an 18" wheel/tire by spacing the balljoint/tie-rod end bracket - you get the same effect as a dropped spindle it will work fine spaced - but to do it optimally - you would need to raise the upper control arm the same amount you space the spindle to get the geometry back to TOYOTA's design.
Tacon19s's avatar
Tacon19s
yeah I have talked with steve about it also. mark my word though...the steering will be an issue, regardless of the spacers, raised arms and everything. keep us updated on the progress
F
FBCsmiley
yea i know steve is cool as shit, he'll talk 4 days lol. i talked to him yesterday and he told me to get some spacer from AIM but i jus figured me payin what ive payed for my upper and lowers that i wouldnt have to spend anymore money. cause the problem is my lower is binding up on the bottom of the frame. therefore keepin the front of the truck bout an inch off the ground. if anybody has any pics of flippin the ball joint it'd be greatly appreciated, cause im feelin like a complete f@*k tard rite bout now. thanx again
draggnmazda's avatar
draggnmazda
i have a mazdab2200 with toyota cando arms and drop spindals and i am running 22s is what i did was put a pocket in the frame so i can run an re7 and i also trimmed some of the plate off the lower arm it lays out fine on mazda but the upper baljoint binds before it gets full lift waitting to se if barely legal will be making the thread in style uni balls for the cando arms i tnink they are suppose to hope this helps u
Tacon19s's avatar
Tacon19s
the pic I posted of PDOGs taco front set up has a flipped lower ball joint and spacers
