removing X runner ground effects
l0wyota
if you remove the 2005-2008 X-runner ground effects will there be holes in the body of the truck? and will there be holes on the fenders if u remove the flares?
prorida's avatar
prorida
ground effects yes theres holes, fender flares i don't know?
time1's avatar
time1
Each wheel flare takes like 6-8 clips that pop into the sheet metal. Im not to sure about the rocker moldings.
l0wyota
thats dumb! anyone have any pics of one with the gfx removed?
prorida's avatar
prorida
well the only thing that makes it an x-runner is vvti in a 2wd chasis and the ground effects kit. so you can pretty much look at a tacoma of the similar year, and there's your x-runner minus ground effects.
Do you have an x and just don't like your ground effects?
sadisticiron's avatar
sadisticiron
what makes it an x-runner is the 4.o liter v6, 6-speed manual trans, heavy duty sway bars,bilstien suspension and GFX. the GFX will leave holes through out the body and fenders
prorida's avatar
prorida
oh ya forgot the 6 speed but you know what im sayin bobby, no difference on the ext. other than ground effects and badges.
jetts
xrunner no body kit, still has the fender flairs cause there is clips that go into the sheetmetal that need to be shaved if u remove them
kzeliminator
that and it looks tits
l0wyota
that prerunner looks sic! i was trying to get that hood scoop and 6 speed without them damn gfx! itd b cool if someone had pics of all the holes that would have to be shaved off an x runner?
