If I was wanting to put right hand driver on my ford. How would I go about doing so? Could I just swap the side that the power steering pump is on or will I have to get a pump that works in the opposite direction?
MF
Master Fabber
To be honest with you the pump does not know if it is pumping left hand drive or right it is only building pressure. Longer lines would be needed, and a rhd rack from something. Also the engine and trans would need to be offset like the factory is but the other way. Good luck would def. be different.
dufur2003
I wonder if I could just do like the old mail cars do and I have a chain running behind the dash.
MF
Master Fabber
That would work too.
WF
Wicked Fantacies
Flaming river can custom make you a RHD rack and pinion
