300c on 24s?
jsondrops@hotmail.com's avatar
300c on 24s?
jsondrops's avatar
jsondrops
will 24s fit on a 300 with stock suspenson?If not what needs to be done to make them fit?any help would be cool,just trying to help the dude at the gas station!ya know what i mean!
AU
AZ UNDERGROUND
THEY WILL FIT SEE SUPERBUY TIRES THEY HAVE ONE ON THER SITE IT ALL DEPENDS ON TIRES..
tcsxtremeison22s's avatar
tcsxtremeison22s
i think they're fine to run with stock suspension...the rear fenders may need to be rolled, and youll need to take down the bolt in the front that sits right above the tire n holds the control arms together...
and may have to do some minor grinding to the control arms as well if the offset and backspacing isnt perfect...
FXDGRND's avatar
FXDGRND
They will fit. There were many MANY at sema a few years ago. Heather drove around a few months before they put farm equipment in Depends on tire size.
project_77
they will fit no problem. with no rubbing. I have done a couple sets out here. Look sick! Hit me up I can show you a couple designs.
dufur2003's avatar
dufur2003
They will fit without any trimming. You just have to have a 275/25/24 tire. I think thats the right size.
BlueJet
275/25/24 is one hell of a o-ring. guess you should stay away from stray pebbles to keep from bending the rim
project_77
ya. 275 25 24 is the tire you have to run.
Texmextukin's avatar
Texmextukin
Yep thats the size.Its basically the same OD as a 265/35/22. We had a charger come into work last week on 24's, and thats what it was rollin on. If you plan to drive daily I would think about that a little more.
