CONNECTING EFI HOSE....HELP PLEASE
92yota avatar
92yota
what is the best way to connect two high pressure efi hoses? im stranded until i can fix this.
kaoss avatar
kaoss
I would (and have) use a barbed double-nipple coupler and some worm clamps.
92yota avatar
92yota
i have tried that in the past, and never could cram the fuel line onto the barbed connector far enough. it was almost impossible since the barbed connector is slightly bigger than the ID of the hose, and the hose is hard as a rock. and i've tried heating the hose with a hair dryer to soften it and all that. it will be much harder now that its 30 degrees outside. is there an easier way to get the hose onto a barbed connector like that?
kaoss avatar
kaoss
spit on it, my answer for all lubrication.
toreadorxlt avatar
toreadorxlt
heat gun..
They sell special high pressure clamps as well for this purpose, I wouldn't hose clamp it at all.
92yota avatar
92yota
Edited: 1/28/2008 9:02:03 PM by 92yota
i've tried a hair dryer before, don't have a heat gun. and it still didn't work. maybe i didn't have it hot enough. should i try to heat it longer with a hair dryer, will that work eventually, or do i have to use a heat gun?
or can i use a push to connect or compression fitting since it is hard plastic line?
onehot69stepside avatar
onehot69stepside
good luck on that. Those hard plastic lines usually cant be fixed. A compression connector might work, but you may never find the right size.
