Nissan Trucks \  how low can a titan get
Nissan Trucks Make Specific
views 213
replies 4
following 5
texasfrontier99   +1y
whats the lowest you can get a titan static droped.
jcjcsoccerkid   +1y
start cutting and find out
jcjcsoccerkid   +1y
start cutting and find out, but if you want an educated guess, i'd say pretty fuckin low.
ahab   +1y
The front struts will bottom out even with lowering springs if you hit a hard bump. I did one that would have been the equivelent of a 4/6 drop and the front bottomed out allot. I cut a half coil from the drop springs though.
dragggn   +1y
I cut 1 spring in front, and am running 3" drop spindles from Bio. My cross member in the front is 2.75 inchs off the ground. With just a little bit of constant weight on the bumpstops, but there not crushed.
rides a little rough, but really not that bad.
In the rear, I pulled 1 leaf, and put longer shackles off of a ford drop kit. I' call it about a 7/6 drop... forgot to measure befor i got started..
