Under Construction \  building a trailer question
Under Construction General Discussions
views 599
replies 11
following 9
framescr8pintoy   +1y
for anyone out there whos built their own trailer. what do you suggest for axles? besides buying brand new ones.. would axles from a boat trailer be sufficient to haul a vehicle? what load capacity should it the minimum be?
get twisted   +1y
first off how much does what you ll be towing weigh? then how much does the trailer weigh? find out those two numbers and go with axles a little more than that but i used 3500# axles one with brakes and if i build another it will have brakes on both axles boat axles might work but it depends on how big of a boat trailer they came off of?
for around $200 per axle new that would be the route i would take
hope this helps some
chunky_thunder   +1y
it depends on the carrying capacity, if it was a bigger boat you will be ok, if it is a bass boat look and see what the actual axle is made out of and how many springs it has, if it is made of 2x3 and has 5-6 springs they will be ok, if they are mad of 2x2 with the same spring count they will be ok with a mini on a trailer i am a shop supervisor at a trailer manufactuer and we build boat trailers for triton boats as well as some custom apps...hope this helps
framescr8pintoy   +1y
it would just be for a toyota.. unless sometime in the future i actually get a fullsize for a project.. i was just looking for some numbers on what to look for so i can keep an eye out for something i might see for sale. id like to buy one, but i have that whole why buy it when i can build it attitude. i usually overkill stuff anyways when i build it.
SHOWTIME   +1y
the min axle capcity i would recomend is 3500 lbs with at least one axle with electric brakes.if you think tha you might ue this trailer for a ton of use and differnt trucks go with 5000 lbs axles a little overkill but well worth he safety you get from having extra weight carrying cap.
lobdyblazr   +1y
man I have always just bought new ones... there is a trailer yard here that will order 3500# axles, built to your psecs for just over cost. I think I paid like $400 tax and all for the last 2 I bought. that was a few years ago, but its worth it still.
bodydropped85   +1y
u can buy an 18ft flatbed car trailer at trailers for less here for 3k. cheaper then building one and faster IMO.
bdroppeddak   +1y
you will end up with more than what you can buy them for, you can get a wood decked 18ft dovetail for under 2 grand....
tuckinlugs06   +1y
im gonna use moble home axles ...if you were close i would sell ya a set..go lots
///RA TROY   +1y
i paid 1800 for a brand new 18ft diamond plate steel deck trailer....its a diamond trailer!! you couldnt build it for that
