few questions
eighty3eighty3@yahoo.com's avatar
few questions
livnthelowlife's avatar
livnthelowlife
got a 90 22r 2wdr with 92 cab...do i have to run 4x4 fenders n bed .....im going with 18x7.5 rims ........need some guidence on fuel tanks to....im lookin for somthin that uses same lines as stock and worthy of being out in open.
societyoutkast's avatar
societyoutkast
i got a plastic rci fuel cell man
lucky_brew's avatar
lucky_brew
get someone to make you a cell that will mount the factory unit. unusual fabrication and mindliss metal fab make them. (last i checked around $250-300)you can also shorten the tubes on the unit if you need a shallower cell.
danc's avatar
danc
pretty sure you don't need a fuel cell if you use a wishbone set up.
NR RailnPup's avatar
NR RailnPup
the 2wd and the 4wd bed is the same for that body
chad (truckrundotnet)'s avatar
But you will need 4x4 fenders for the front.
livnthelowlife
fuck i was hopin i wouldnt have to use those.....ohhh well guess ill go with the 4x4 bed also........and im not mounting the tank factory .propably sunk into bed floor in rear.....dangerous hopfully no rearend colisions
TwistedMinis's avatar
TwistedMinis
2WD and 4WD beds are identical those years. There is no difference. And you can run 2WD fenders also, they just don't match the rear fenders. If that doesn't bother you there is no reason not to run the 2WD fenders.
You can get an RCI fuel cell. They are cheap, and the don't leak. But in my experience, none of them have been square, and they are all wavy. You can get a fuel cell made that will except the stock sending unit. That would be your best bet. I know a guy who builds some incredible stainless tanks, but you will spend at least $500.
livnthelowlife
thanks seth .......i kinda like the 2wd shit better for some reason.i was thinking of using an old airtank for a simi truck.all sending units are pretty much the same arent they?
TwistedMinis
Not really. They usually have different readings. The standard 0-90 ohm that come in fuel cells work well with after market gauges, but not so much with stocks. I think they read backwards, or just aren't accurate.
