Ford Trucks \  f-150 tuckin 22's??????
Ford Trucks Make Specific
views 228
replies 7
following 5
DSK2k2   +1y
i have a 2000 f-150 with 20's and it lays out with NO problem. i want to run 22's front and rear. what has to be done to get it to lay out with no rub in the rear??? any pics or info will be great....thanks alot!!!
lascrew   +1y
Edited: 2/8/2008 4:16:21 AM by lascrew
You're going to have to do some notching in the rear. I don't lay on the frame; about 2
Master Fabber   +1y
Not trying to be rude, but why even go to the hassle of cutting the bed for a notch cover if the truck wont lay? That is like a 1.5 inch bed cover.
DSK2k2   +1y
well thanks for that.from the looks...why dont you take out the stock tubs and add a bigger notch....
did anyone have to flare a fender or narrow a rear end to get them not to rub in the rear????
DSK2k2   +1y
calisupercrew..........what did you do under the hood? any relocating besides the battery???
BIGRIGZ   +1y
To lay frame I had to cut the inner fenders alot and notch the firewall a little. I can't remember if the booster was a problem then but, it was when I did the body drop. Then I went with hydroboost. I think traditional bodydrop on a bed / raising the bedfloor looks really good cuz the bed looks mostly stock and no notch cover in the bed.
DSK2k2   +1y
(ken riggs)---ok.....thats sounds bout like what i was thinking. but you didnt do anything else to the rear of the truck? what kind of set up are you running in rear? looks like not to much camber up front....what the secret??? thanks for the info!!!
bbb   +1y
How much did you have to go on the fire wall? Did you have to mess with th a/c? And last question, Do you have to notch the lowwers to lay the 22's?
