Full Size Truckin General \  air ride strong arm help
views 212
replies 8
following 6
70cst10   +1y
SPENT 850 DOLLARS ON THIS KIT AND THE LEAST THEY COULD DO IS GIVE ME SOME INSTRUCTIONS!! well now that im done yelling can someone tell me if the upper ball joint goes in on top of the a-arm of does it bolt in on the bottom of the upper control arm..also they gave me 2 sets of bolts for the upper a arm which one do i use ones tapered and the other isnt . and another thing they didnt send me any washers .., do ineed to use lock washers on the upper ball joint in the strong arms ?? oh ya im working on a 96 chevy 1500 extened cab
unusualfabrication   +1y
Did you check their website to see if they have installation instuctions for them?
70cst10   +1y
ya i looked and didnt see any
SHOWTIME   +1y
70CST.there directions are very bad!the upper ball joint goes in from the top just like the factory ones.You shoud have gotten some bolts with lock nuts to install them.for the bolts use the one that are like your factory ones.One thing to look at also there is no place to mount your brake line to also.i called them and they said just drill a hole in the arm.DO NOT DO THIS.I got a couple of clamps that are coated in rubber and used them.When i questioned them on why they would not put a tab on were you could bolt the brake line to they could not answer it.If you still have problems putting them on go and buy a chiltons manaul those books are a gold mine and help a pile they cover evry thing to do with those trucks.I did them on my 1991 extened cab.
70cst10   +1y
cool,,ya def gonna go get a chilton manual cause they didnt give me anything ..i just cant figure out why they give me 2 different kind of bolts one with a taper and one without and only 4 nuts and no lock washers?,,, i thought they had their sh*t together but i guess not ..
Low_Smooth_Cool   +1y
whats your e-mail address I will shoot you over the pdf file for the instructions asap you should have recieved the instructions they would have come in a white envelope that says "do not open" as a joke.... Longlow no one here would tell a customer to drill a hole into his new control arms and if so I would like to know who told you this at ART?
dragginsteel67   +1y
You should post that pdf to a hosting website and then link it into this thread, it will help lots of guys out that have these arms.
Low_Smooth_Cool   +1y
we do have all the pdf files on our website here is the link to our pdf instructions..
http://www.ridetech.com/more/test-posting/
YeLowFuLLSiZe   +1y
i ordered a set of art strong arms for my 93 chevy x-cab and mine didnt come with no instructions neither thank god my boy knew how 2 do it and i also needed to notch the frame so the control arm will clear. other than that i have no complaints
