Im sellin my tow pig
got6wls avatar
got6wls
Here is the link for my add on craigslist, im sellin my pig in hopes of getting an older one. I can't have 2 the wife says, I have 3 other squarebody's in the works and 2 dually's take up tooooo much space here at the casa.
wide load c-30 avatar
wide load c-30
I read your ad. I'm assuming you are running Western Chassis 3" springs and you cut them to lower the truck another inch? How much did you cut them and what shocks are you running? Do you have any pics of how much shock travel you have left?
got6wls avatar
got6wls
No Western Stuff on my ride, the kit that is on it is older BelTech kit which is no longer reproduced. The springs came with the kit. I cut 1 full ring out of each coil, a little less out of the driver side as to not show sag when I was really the only one cruising it. Shocks are toxic shocks. Every truck is different so depending on the ride you want you need to determine your distance in your stroke. When the truck is sitting static there is about 2" of stroke left before bottoming out. Total shock travel is only about 8".
giovanni avatar
giovanni
LOL
big bear avatar
big bear
heres the truck i believe hes selling. lol i knew i wasnt losing my mind.
luv2xclr8 avatar
luv2xclr8
I looked for it too Bear and couldn't locate it.
Hell of a deal on very nice Square, Good luck!
