Control arm ?
Control arm ?
W
wannadrag03
What would be the plus side to upper and lower control arms ? My frount end has drop spindles flipped ball joints bags of course.My uppers arms are not raised. thanks
thacru78's avatar
thacru78
Raising your uppers will help with the excessive camber. Most people running 22's raise them 3 inches. People using stock arms as compared to the Ekstensive arms seem to have problems with not as much lift, and bumpsteer. I could untuck my 24 by 4 inches and had very very little bumpsteer. I was running the Ekstensive LCA arms. Only way you will be able to run Tubular uppers and get enough travel out of them is using a Uni-ball. THe stock uppers get tons of travel.
W
wannadrag03
THANKS FOR THE INFO ..Sounds like I need to just run LCA and maybe raise my uppers
