Dodge Trucks \  02 ram help
02 ram help
Dodge Trucks Make Specific
views 282
replies 7
following 5
camarors96   +1y
A buddy of my is getting ready to bag his 02 dodge ram, but right now he just wants to bag the front. what would be the easiest way to do this? thanks
z71mazda   +1y
hey man the easiest wy to do that is to get a do it yourself kit from suicide doors.com and make your own bag cupsthen the rest is real simple you dont have to buy drop spindles or any thing
thacru78   +1y
That's if you want to lay out on a 15 inch rim, or not lay out at all.
daveg   +1y
spindles from mcgauheys (? on spelling), ekstensive lower control arms, and raise ur uppers 3".....
bigjon   +1y
dodge and easy dont go in the same sentence!
you need to cut the front spring buckets off the frame, torsion bar brackets are a must, having the ekstensive arms helps alot or you need to notch the pockets the control arms mount to, raising the upper control arm mounts will correct the super bad camber, and if you want to lay true rail and not just the front crossmember you will need to z the front clip 2 1/2 inchs. I have some pretty good pics in my profile and so does "BIG" hes has done it all so he is a great resource if you have question.
thacru78   +1y
EK/My arms, modified spindle to accept the chevy balljoint, raise uppers 5 inches, bag bracket, tub firewall, 2.5 inch Z will get you laying true rail on 24's withou having to buy drop spindles. For 22's, all of the above except you don't have to tub the firewall for a 265/35/24 and you only raise the uppers 3 inches. This will get you 6 degrees camber layed out, +1 degree camber at full lift, which is 4 inches above the tire. If you got anymore questions ask away. If you need some LCA's hit me up.
thacru78   +1y
thacru78   +1y
Not sure why that happened
