Mini Truckin General \  fittings
fittings
views 541
replies 17
following 13
dragnranger   +1y
what do you use? compression or push fittings. i have never used compression or push fittings. i have always used rubber hose with clamps. what are pros and cons? i am putting air cylinders on a civic using 3/8 line and valves but dont know what fittings to use.
fatboysS1O   +1y
its just folks preference. but i like PTC fittings personally. lil expensive but easy to use. theyre "dummy" friendly i guess u could say. u just push the air line in until it bottoms out then pull back.
simple-pleasurez   +1y
how about "d.o.t." rated vs ones that are not. i got some fittings from work where we run 200 psi 24/7 with no probs. but they are not dot rated.
homebuilt   +1y
i mix and match. all of my fittings are from home depot. knock on wood no problems so far (6 years).
lost cause   +1y
I always heard that push fittings leak?...I dunno.......
kzeliminator   +1y
never had ptc leak on me, make sure the line is cut straight and seated all the way
you can try these guys or sd.com
http://www.poweraire.com/
86mazda   +1y
i can get parker push to connect fittings cheaper than sd lmk.
kotalaynframe   +1y
you can go to the big rig shops they have all kinds of fitting and cheap too i usually get the ptc fitting beacause they are easy to install
laydsuzu   +1y
I have ptc everywhere except for on top of my bags, which are compression. I have a small leak, but guess where its coming from, the compression fittings
decivic   +1y
i have always used push fittings. never had problems
