wiring help
wiring help
scrapinranger
Ok here goes, Doesnt start with key, gauges dont work but do light up,turn signals dont work and the hvac doest work. What can I do or has anyone had this before??
Afro's avatar
Afro
Problem is in IGN fuse, relay, or Whole system. Check all fuses (probably a master fuse), especially the big ones under the hood. All of those things are typically IGN devices, same as your fuel system, etc. Start there
overkillFFF's avatar
overkillFFF
if it lights up then your constant pwr, so it's probably something to do with you ignition circuit. If your truck is newer, you will have a fuse for your ign in the fuse/relay box in the engine bay.
