Carpet for stock floor?
FreelandKustomz avatar
FreelandKustomz
I know a toyota carpet kit will not work because of the humps, who makes a modable carpet kit??
gorillagarage avatar
gorillagarage
so its channeled?
FreelandKustomz
no not at all. the floor is compeltely stock, just the transmission tunnel and driveline tunnel are raised a few inches. so the carpet doesnt fit at all. I need something i can form myself
twistofcain avatar
twistofcain
i know they make a stretchable carpet to mold around contours in the floor board
2dxmazda avatar
2dxmazda
call acs or acc and ask for raw materials you will buy it buy the yard like tweed standard cab about 3 yards should work x cab go with 4 and if it is a crew go 5 yards. you want the length of or width of the roll to be at least 2 inches that way you will have extra hanging out the doors to cut and trim. also make sure you buy at least 3 yards of carpet jute. that will help with sound.
YOLO avatar
YOLO
ya, just buy automotive carpet. you can heat it with a heat gun if you need to. it is really easy.
Severed701 avatar
Severed701
i formed my own carpet in my taco and that sucked ass!! would never do that shit again
standardbyker88 avatar
standardbyker88
what they said is about the best route. for traditionals you can get the kits untrimmed so they have extra on the edges, then you just make it fit and trim it yourself. but a stockfloor, it sounds like you might have to make your own. shouldnt be that bad. well, let me rephrase...cant be worse than removing a spray in bedliner...
DPS avatar
DPS
Just cut the factory carpet strait down the middle over the trans tunnel. Then build a full lenth center console to cover it. Non of the aftermarket carpet is werth a dam original carpet is 100 times better.
crewcabondubs avatar
crewcabondubs
accmats.com has factory carpet kits that u can get uncut meaning the sides are longer.
hope this helps
