puttin headunit in dash
17 following
slamedb22
Edited: 2/20/2008 5:55:28 PM by slamedb22
any pics or info on doin dis i kno all da cuttin part but do u use a certain dash install kit????
karathos's avatar
karathos
Didnt want to be the one to do say this...but WHAT? Man i'm as ghetto as the next, But try some english and maybe we can help...also what are you trying to install it in? Also what all are you trying to ask help about?
Sorry man, Just i needed to throw that at ya
slammedtoys's avatar
slammedtoys
Edited: 2/19/2008 5:44:05 PM by slammedtoys
yo fenna do is go to da pizart stizor and scoop up one dem scoshe kiznits see dem thangs fenna scwizze right in and den yo hed unit fenna slip and slizzide right in place YO YO. dats all da infoon i got
mazdalowandslow's avatar
mazdalowandslow
Wow... Serously dude... English! And put up some info on what you wanna install.
ustarin's avatar
ustarin
The sad thing is i understood that...nice.
slamedb22
im talkin bout installin da headunit under da heater controls....soo i was guessin a mazdainstall kit would work soo i was curious wat everyone else was useini already kno bout trimmin all da metal supports in dash and trimmin da heater vents..jus trin oo see wat everyone was usein to clean up da space oneach side of da headunit cause there will bea gap on both sides
dragginmazda86's avatar
dragginmazda86
You dont need a stereo install kit, all you need to do is remove that pocket trim so your stereo cage will fit in. You will have about a half inch gap on both sides of the stereo. The heater vents are the ones that are trouble but i've done this to five mazda's before it fairly easy, alot easier than reading you post's. WOW I've been drunk off my ass and have spelt less words wrong. I dont normally point these things out but that post takes the cake.
livin503's avatar
livin503
Your only option is to just make filler pieces for each side of the pocket if your putting it in the middle of your dash.
Good Luck Homie!
LowOrange88
What the Hell? I understand speaking like that, but actually typing it out, thats a fuckin' joke!
layedoutb2k (chase)'s avatar
layedoutb2k (chase)
IMO its easier and looks cleaner to put it in the stock location and make one filler panel that wraps around instead of tryin to make 2 little 1/2" wide ones when you stick it in the dash.(unless of coarse its bodydropped and you cant use the lower piece)
