cleaning gas tank
sheffieldced@gmail.com's avatar
cleaning gas tank
Tacon19s's avatar
Tacon19s
The tank has been sitting for 3 years with no gas in it. The fuel pump has been out of it occasionaly also. Gonna be firing the truck up in a couple weeks and need to know the best way to clean it out to be ready for fresh gas....thanks
cap10rob's avatar
cap10rob
Glad you posted this, I am in the same boat with my 67. It has been sitting for 4 years, and there is no gas left. I plan to lock myself in my garage for a weekend and get it running this spring.
simple-pleasurez's avatar
simple-pleasurez
take it to a radator shop and have them boil it.
oneup's avatar
oneup
Or go to your local hardware store and get some muriatic acid just swish it around for a few seconds and spray it out real good it will eat it all away make sure you get all the water out when you rinse it though best way to be sure is to use an air chuck to spray it out after you rinse the muriatic out. Just to warn you though they may think your cooking meth.
bodydropped85's avatar
bodydropped85
if its not rusty, wash it out w/ acetone. i would use this oppurtunity to use the POR 15 gas tank sealer kit, which comes w/ a prewash and sealer so itll be jam up jelly tite.
Tacon19s's avatar
Tacon19s
Edited: 2/19/2008 7:35:48 AM by Tacon19s
sealer as in seals up all the inside surface of the tank?
dan48p's avatar
dan48p
yea the stuff in mine looks kinda like a red rubbery type stuff...
the radiator shop i used charged 60 bucks to clean it and seal it so for that i didn't want to dick with it.
but the one i'm using was sitting in a junkyard for a few years and stunk... it was so nasty in there the sending unit rusted in half
