Full Size Truckin General \  need help with a 07 dodge
views 136
replies 2
following 2
ddranged   +1y
ok so i got a buddy with an 07 3/4 cummins. well he has 18x10's with a 33x12.50 on them, with a two inch leveling kit. well the problem is that the wheels and tires rub on the back of the wheel well on the inside when turned most of the way to the right or left. any one seen this problem? well i know it seems to just rub the plastic wheel wells but it is on a nub, and didn't know if there was a steel obstruction behind it, figured some one else has had to have seen this problem before.
gimp5561   +1y
you have the wrong offset wheels. I work for dodge and install 20x10's a lot and never had a problem.
and know there is nothing behind the wheelwell liner. there is only 8 bolts hold the liner's in in the front so you can take theme out and see if it still rubs if not trim the liner while you got theme out.
ddranged   +1y
well i figured they were to far out of the fenders but will look bad ass with the flares. but i do appreciate your help. cause i think they are a -24mm, what should they be on a 18x10
