Ford Trucks \  hey James i need your help...
Ford Trucks Make Specific
views 270
replies 7
following 2
grillift   +1y
I need to know what the dohickey is that my brake line go into from the master and then come out of and goto the calipers and drums. Is it the proportioning valve and abs in one? if so can I remove it and just run a prop valve? Its on a 95 ranger and is the main thing in the way to lay it out on 20's. Thanks
bodydropped85   +1y
yup just swap to a non abs prop valve(88 down usually) youll have to redo some brake lines but itll work just fine. is yours a rear or 4 wheel abs?
grillift   +1y
I dont know how can you tell?
bodydropped85   +1y
is there a wire going to the front hub assembly? if not then its rear abs only and much easier to swap(less lines)
grillift   +1y
sweet i'll check it out tonight. your the man James
bodydropped85   +1y
np if yours has jsut RWABS then you should only need to redo just the rear brake line and not all 3.
grillift   +1y
If I only prop valve cant I just put that to the front and back and if I need to "t" the front into one. right?
bodydropped85   +1y
huh? yes the front is t'd
