Interior \  door poppers diagram/1st time help
Interior Q & A
views 3442
replies 8
following 5
sittin_so_low   +1y
Edited: 2/22/2008 3:40:52 PM by madmax95
ok, i got the autoloc door poppers, can some one post anything to help me out hookng this up, pics, info, tips, anything. it shows 86 and 30 on the relay going to the battery? why 2? also, what goes from the relay to the remote transmitter? any help please.. i can do this, just need some help! i just need to pop open my doors, thats it. nothing else im using..anyone? thanks
oh yea, its on a 96 sonoma/s10
jerid   +1y
since your hooking up the door popper kits and more than likely not running door locks.. (correct me if im wrong)
blue and black wire (30 & 86) go to battery
yellow (87) is straight to the solonoid
white (85) goes to your brain box.
now...all you need to worry about with the box is
red and blk (of course your fused hot and ground) thats a given
yellow is key on acc. (duh)
i always hook up the drivers side white wire (85) to the blue/white wire on the brain
and the passenger side (85) to the green/white
hope that helps everyone out.
BTW dont worry about hooking up the parking signal lamps...half the time it doesn't work
lost cause   +1y
Now thats what I call help!
sittin_so_low   +1y
Edited: 2/22/2008 4:18:20 PM by madmax95
oh yea, yep, no door locks...jerid, thanks alot. i talked to u a few hrs ago...lol lol i just needed this to help me out. i dont want to have someone else do it cause i know i can, but its a first and i want it donw right. thanks again, this is going to do.
one more question.... whats the valet switch thing on the transmitter?
sittin_so_low   +1y
Edited: 2/22/2008 4:22:50 PM by madmax95
white wire goes to brain box, what color on the box? lol i might sound stupid, but hahaha thanks
( ok, the white wire goes to on one side the blue/white and on the other side ( pass door) it goes to the green white) yea?
sittin_so_low   +1y
Edited: 2/22/2008 4:25:30 PM by madmax95
Edited: 2/22/2008 4:23:50 PM by madmax95
also, whats does the yellow is key on acc. actually do? does that q make sense?
i cant say thanks enough.....
last question...when its all hooked up, i just hit button 1 ( driver) or 2 for pass and door and thats it?
sittin_so_low   +1y
Edited: 2/22/2008 4:51:34 PM by madmax95
so on each pooper i hook up a relay, white goes to the brain on both,(b/w- g/w) yellow goes to the popper on each, then i run the blue and black on from each relay to the battery? what about the thrid relay?thats for the transmitter? work with me, i might sound stupid, but i have to ask to make sure..
jcjcsoccerkid   +1y
what happens if you dont use a relay or a fuse on the hot wire going to the battery??
LowOrange88   +1y
make sure you put an emergency button somewhere, or even some type of mechanical pull cord to pop the door if you ever need to, incase of a dead battery or blown fuse. never hurts to cover all bases. Beats a broken window.
