ATTN: SHAVED DOOR PEOPLE?
11 following
badlukvc@gmail.com's avatar
belowclvl's avatar
belowclvl
I have a 2002 dodge ram that is bagged. well i have to bed off changing my air line out. well i finally finished tonight and i go to try to get in my truck and i cant get the doors to pop open. Its clicking on my passenger side like it wants to open but nothing. so needless to say i cant even get in my truck. Is there any way my battery could of gone dead or what i dont have the slightest clue. please help.
onebadkota's avatar
onebadkota
I have the same problem right now...except i do have the windows down, and a manual way to get in.....I would say check your battery first..even if it has some power, u need a lot to get the solenoids to fully work.....if they sound weak its prob. the battery....OR...if u are using a remote, check the batteries in it...once it gets too low, the signals dont pick up strong enough....if u have grounds outside the vehicle, make sure they are good and connected....other than that im not sure what it would be unless its a bad solenoid (but if its clicking i dont think that is the case)...good luck with it
KNDAlow's avatar
KNDAlow
id say if its clicking the battery is weak, had the same problem a couple weeks ago on my bros truck
societyoutkast's avatar
societyoutkast
i hated this man it happend to me all the time i just got another battery lol and it worked ok but it does take alot of juice for some reason
tuckinlugs06's avatar
tuckinlugs06
yea mine did that to and one time it was the ground ..somehow the door was not grounded verywell not sure how...and i have a hood cable hocked up the the handle and threw the jam so when the batt goes dead or they dont work
belowclvl's avatar
belowclvl
thanks a million guys. trying to get ready for tex mex.
banginfullsize6
Im always havin trouble with mine. I've want there three windows. My solenoids get water in them and frozen in cold weather. now i just leave my window half way down.
Lucky's avatar
Lucky
I used to have that problem in my civic.....I used to push in on the door while it clicked and it popped the door open
974door's avatar
974door
I would suggest this once you get it open...http://store.summitracing.com/partdetail.asp?autofilter=1&part=ELI%
laydsuzu's avatar
laydsuzu
try pulling on the top of the door when u try to pop it, sometimes it just cant pull enough sometimes or the cable is loose, happened to mine once
