how to install a hei distributer
johnz
ok so i know this seems simple enough but i have no reference mark on where to put the vacume advance
lowdyme's avatar
lowdyme
it usualy is twords the right valve cover when sitting in the driver seat also wherever you want cylinder 1 to be you should set the rotor one toother be4 there so when you spin in to drop it in can spin to the right spot also cyinder 1 should be on top dead center and cylinder 1 can be any terminal on the cap it dosnt have to be in a certan spot just make sure i know where one is and go from there with the firing order 18436572
