do i need two pressure switches?
stopndrop
hey guys i wanting to know if i have to have a pressure switch for each compressor or can i just wire both of them up to one pressure switch? i have both of them wired up to one pressure switch right know and it seems to work good but will it mess anything up. lmk know guys i would really appreciate it. thanks
Draggin2hell's avatar
Draggin2hell
one is just fine ive had mine like that for 2 years with no problems
drgnaccordwgn
my reccommendation is one pressure switch and 2 relays, i have always run the 80amp relays from stinger. they do the job great. however i have always run mine on a negative trigger with a 40-50 amp fuse on each of the compressors. run a 4ga or bigget from the battery up front to a 80-100 amp fuse holder less than 18" from the battery, then to a fused distribution block in the rear, then from there to the comps. ground one side of the pressure switch and run the other to the activation side of the relay. you will also need a 12v constant for the trigger on the relay. then take the groung side of the comps to one of the large posts of the relay and the other post goes to ground.... and.... the you have it a negative trigger system for the compressors...... i have done plenty of systems that way... it's easier on the relays that way...
and remember there are always more than one way to skin a cat.....
FreelandKustomz's avatar
FreelandKustomz
yeaup what he said, one pressure switch and two relays. Or you can run one 80 amp selinoid
DooredFord's avatar
DooredFord
I have 2 compressors, 1 pressure switch and a solenoid. Works fine
Low_Smooth_Cool's avatar
Low_Smooth_Cool
one will do just fine
stopndrop
thanks guys
s10
last post by baha +1y
